GregValiant 1,112
QuoteNote: I have tried using pause at height feature by adding end G codes at that height condition, but it is pausing just for about 10 sec and starting next layer of print. Is there any solution for this?
Maybe.
What printer are you using? Creality printers (and some of their clones like Anet's) have known issues with "Pause at Height".
After the pause gcode line (M0, M25, etc.) there is an M109 line and it is that M109 line that may be causing the "pause" behavior as it typically causes a 10 second delay while checking that the temperature is up to the set point.
There are a couple of workarounds that may fix this behavior. Let us know what printer.
gr5 2,071
"Pause at height" - should not continue after 10 seconds. It should stop and sit there and the printer should ask for input from the user. At that point most users can cancel the printer. However every printer is different.
Also your hack of adding the "end gcode" should work but you should delete everything from there to the end of the gcode file.
