Hey GregValient
Seen you pop up on other issues with Xvico. Thanks for still being here and sorry for the delay in response.
QuotePost two gocde files here. One that works and one that doesn't. Make sure you name the files so folks can tell which is broken and which works.
Attached two files as you asked for.
Edit I found that the broken gcode file that was attached spits out gibberish when opening in plain text - sorry very confused and turned around at the moment.
Can't for the life of me remember what I did before as I had to set it up twice. Want to say it's using the Ender 3 settings on an older version of Cura - then every update just copied my settings but unsure ?
Sorry about all this , actully looking at getting a new printer (Ender 3 pro)but would like some help figuring out what the issues are with Xvico (Their email seems to be down as-well so no luck)
Edited by CharlieB90
GregValiant 1,142
That all looks normal. You should probably take out the "M140 S0" line from the Ending Gcode. It shuts off the bed heater and since you don't have one it can cause problems but at the end which isn't THE problem.
