That sounds about right!
I'll give it a try when back home. Thank you for the very well explained answer.
And also thank you for the extra tip about the extra skin wall. I don't know when or why I set that one to 0, but I was definitely looking into getting these walls back. It did give some troubles on a few prints indeed.
GregValiant 1,110
It is a function of the ZigZag pattern. Changing to "Lines" will eliminate the shuffle movement.
The end extrusions of ZigZag will maintain a tangency to the hole feature. There are no circles in FDM and so you have a number of short line segments (the number of which is likely dependent on your "Maximum Resolution" setting) and those short line segments approximate a circle. In addition, those short line segments pass back over the last long extrusion before the inner walls of the hole. The setting "Compensate Wall Overlaps" might be involved. I don't have 4.11 installed but in 4.12 the "Monotonic Top/Bottom" setting would be involved as well as Cura tries to keep everything moving in the same direction.
At any rate, the nozzle is going back and forth putting in those short line segments.
The alternating magenta and white colors are the segments of the tangent end extrusion. In this particular slice the length of each segment is about 1.06mm. If your travel settings are set for retractions at 1.00mm of travel then there will/might/possibly be retractions between line segments when the nozzle changes directions.
It appears that you have "Extra Skin Wall Count" set to 0. The effect of that will be that the end of the zigzags along the straight edges of the area will be over voids in the infill and will sag into the voids because they aren't supported and there is no "Extra Skin Wall" to bond to. Eventually that would fix itself as some support is gained when the sagging previous layers firm up and provide some support for the latter layers. At a micro-level that could effect the strength of the feature that will be built above that flat area.
That's what it looks like to me.
I've been known to be wrong.
