It's an Ender 3 V2. I haven't calibrated it, I'll try that.
How can you tell visually if it's under-extruded vs over extruded?
Thank you!
Thank you!
The top layer (without ironing) is pretty good for checking. Use a magnifying glass and look at it. If you can see a checkerboard and the layer below the top layer is visible through gaps (in the top layer) then it's under-extruding. Each extrusion should be nicely welded to the adjacent extrusion.
If the extrusions show ridges between them then it is likely over-extruding.
A lot of printers need the E-Steps calibrated. It isn't a difficult process and I'm sure CHEP has a video on YouTube on his Filament Fridays channel. When the gcode asks for "X" amount of filament then exactly X amount needs to be delivered. If it is more than X then there is over-extrusion and when there is less than X then it is under-extrusion.
GregValiant 786
In the "rough" part I'm seeing some checkerboard pattern. You didn't mention the printer but if it's a non-Ultimaker printer did you happen to calibrate the E-steps?
If the top layer is under-extruded you could try turning UP the "Ironing Flow" to compensate at least a little. I'm guessing that this is the problem so try turning the Ironing Flow up to 13%.
If the top layer is over-extruding, you could try turning DOWN the "Ironing Flow" to compensate. For a reference I run "Ironing Flow" at 7%.
When the combination is an over-extruded top layer coupled with too much extrusion during ironing ridges develop as the nozzle starts to bulldoze material and make a mess.
