OpenGL 2.0 Required with an update to CURA and Ubuntu Jammy/CURA 5.1
silver2row
Posted · OpenGL 2.0 Required with an update to CURA and Ubuntu Jammy/CURA 5.1
Hello,
I am not sure how to install OpenGL 2.0 w/out installing Debian Bullseye or by installing a file outside of apt.
I tried python3-opengl w/ apt and this did not work.
Anyway, here are the errors in case others have situated this issue so far.
PyInstaller/loader/pyimod03_importers.py:495: DeprecationWarning: the imp module is deprecated in favour of importlib and slated for removal in Python 3.12; see the module's documentation for alternative uses
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
libGL error: MESA-LOADER: failed to open iris: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
Anyway, thank you in advance for just looking at this issue.
Seth
