I've had almost zero problems with my machine that were caused by my machine and the Ultimaker S5 is my recommendation for everyone who asks me about 3D printing. I also bought mine in late 2020. I've been super happy with it. I'm surprised by your experience with your machine.
To answer your question, "Is there something good in the UM5 ?", Yes everything is good about it!
I read your posts and think that alot are probably a machine problem, probably a loose connection in shipping. You mentioned that, but I suspect you may have more or the one that came loose is still not seated quite right. Could be the connector to the board is messed up.maybe a cracked solder joint on the board that doesn't cause problems until the board gets warmed up. I had a PC like that once.
I suspect you also may need to put your machine on an UPS with AVR (uninterruptible power supply with automatic voltage regulator). some of you issues sound like they could be power related. I had a lot of "ghost in the machine" problems with both my PC and my S5 at first. When I plugged them into a high quality UPS instead of a cheap surge protector 99% of all my problems disappeared. I spent so much money on the PC and S5, it seemed like nothing to get a $300 UPS to protect them. All my weird PC freezes and glitches (thought I had a virus, but it was bad power instead) went away.
Also a Community forum is not the same as contacting Ultimaker Support. We all try to help each other as much as we can. But for real support and warranty issues, it is always best to actually contact the company directly. Ultimaker makes it very easy to contact them. You can't be mad at them when they don't see a post on a community board. It isn't a support ticket system.
Edited by kayakbabe
Smithy 1,146
Not really, the forum is a community forum and often Ultimaker employees are answering some posts, but it is not an official support forum.
Best would be to contact Ultimaker support directly:
https://support.ultimaker.com/hc/en-us/requests/new
LePaul 358
Wow, your machine/system certainly has some issues.
I'm sure someone from Ultimaker will reach out about this, such as @SandervG to help you.
You made a big investment and you certainly need someone to help you through these error messages.
