Posted · Changing infill type/density above certain layer?
Is there any setting in cura (4.12.1) to let me change to a different infill type and/or density above a particular layer number or height from the bed in mm. There's a print where I'd like to try 50% infill near the bottom but then switch to solid infill 100% density for the upper few cm of the part. Thanks
    • 1 month later...
