Hmmm really don't know where to write in this code....
GregValiant 786
In Manage Printers and then Machine Settings de-select the "Origin at Center" box.
I did that already unfortunately no help😪
Save a project with File -> Save project... an post a link here. Then we can see what is going on.
Cura only saves when you restart it.
I am so sorry, I didn´t know that...
It is working now.
but thank you for the tipps it lead to the solution.
While I´m here do you guys know how to add a Z-Offset to the I3?
It seems that it can not be done in the printer itself only through software.
I have Pronterface and Cura. Is one of the two able to do this?
Thank you for all your help and the time involved 😉
Chris
There's a plugin in the Marketplace for Z Offsets, but it is only meant for small adjustments. If you need an offset of more than a mm or so, you should really adjust that in your printer/the printer firmware.
GregValiant 786
Your printer Origin is the Left Front Corner NOT the center.
This is from the definition file of the I3 Mega S
"machine_center_is_zero": { "default_value": false },
So de-select it.
