Solution resolved-- thanks Greg, apparently I somehow disabled all colors produced under 'Line Type' 🤦♂️
Thanks for your help!
1
GregValiant 786
In the mid-top of the preview screen there is a drop down for "Line Type". Make sure you have them all turned on except for "Only Show Top Layers".
ahoeben 1,654
"Only Show Top Layers" will only be an option in "Compatibility mode", which OP is not using.
In the 3rd screenshot, the horizontal slider at the bottom is at the beginning of the layer. If you move it from left to right (or press the "play" icon), you will see the top layer being filled in. Sometimes Cura gets confused whether it should be showing just the top layer in color, or all of them. Normally scrolling through the layers with the vertical slider will fix that.
