On 8/9/2022 at 7:20 PM, IRobertI said:E-step calibration is not something that is generally needed or done on an Ultimaker 3, something else is causing your problems. If you describe the problem in detail, ideally with pictures as well, we can start figuring out what's going on.
Hi, okay so my problem is that the print layers are inconsistent, It appears to be smoother and almost perfect on the X axis, but the Y axis has the issue. I went through checking for play on the axles, tightening them and all that. It was working fine before I got it (the old owner included some test prints) so I'm guessing something got bonked on the trip to my place. If that helps
IRobertI 517
