Cura 5.1.0 on Linux Mint 20.2 Uma/20.3 Una (Ubuntu 20.04 Focal Fossa)
jayrugman
Posted (edited) · Cura 5.1.0 on Linux Mint 20.2 Uma/20.3 Una (Ubuntu 20.04 Focal Fossa)
Has anyone been able to get Ultimaker-Cura-5.1.0-linux.AppImageCura (or any cura 5 appimages) to work on Linux Mint 20.2 (UPDATE: I upgraded to Mint 20.3 and still have the same issue with Cura 5)?  Ultimaker_Cura-4.13.1.AppImage works fine. I've scoured the web and haven't found anything recent - for Cura version 5. I'm raelly excited about the new slicer features and want to get it working soon.
Here is the output when I run it from the command line (I get the initial splash screen, then it hangs for a really long time until I cancel):
 ./Ultimaker-Cura-5.1.0-linux.AppImage
PyInstaller/loader/pyimod03_importers.py:495: DeprecationWarning: the imp module is deprecated in favour of importlib and slated for removal in Python 3.12; see the module's documentation for alternative uses
QApplication: invalid style override 'kvantum' passed, ignoring it.
    Available styles: Windows, Fusion
QQmlApplicationEngine failed to load component
QQmlComponent: Component is not ready
^C
The logs look like there are many missing dependencies. Correct me if I'm wrong, but aren't app images supposed to contain the dependencies? At any rate, I see a ModuleNotFoundError saying "No module named 'PyQt5'." Is this a Python module?
When I try to install this with pip3, it looks like I already have it:
pip3 install PyQt5
Requirement already satisfied: PyQt5 in /usr/lib/python3/dist-packages (5.14.1)
I guess the appimage isn't using my local python modules or it's a module for something else? If so, what?
I also see a number of plugin import errors. Are there plugins I should remove from within Cura 4 so I can successfully start version 5?
I have attached error and warning logs from /home/my-user/.local/share/cura/5.1/cura.log  and can post more upon request.
Thanks a Ton for any help!!
Update
I've updated my system to Linux Mint 21, Vanessa, which is like Ubuntu jammy, and I still have the same issue, this time with Ultimaker-Cura-5.1.0-linux-modern.AppImage
 appImages  ./Ultimaker-Cura-5.1.0-linux-modern.AppImage
cura_errors.log
Edited by jayrugman
I updated OS
    • jayrugman changed the title to Cura 5.1.0 on Linux Mint 20.2 Uma/20.3 Una (Ubuntu 20.04 Focal Fossa)
    • 1 month later...
    Posted · Cura 5.1.0 on Linux Mint 20.2 Uma/20.3 Una (Ubuntu 20.04 Focal Fossa)
    Hello i have exactly the same problem on Manjaro up to date.
    I have found this but don't help me :
    https://forum.qt.io/topic/126822/cura-does-not-start-qqmlapplicationengine-failed-to-load-component
    And it seems that Ultimaker have deal with this.. but nothing work since Cura any of the 5xxx or 5 beta version..
    And others and many other post but any help me..
    https://stackoverflow.com/questions/18024207/qt-warning-qqmlcomponent-component-is-not-ready
    https://forum.qt.io/topic/54517/solved-qqmlcomponent-component-is-not-ready
    I have see same problem here.. so tell on the post:
    Hello One user of the Manjaro Team have reply to me and give me the trick thats works...
    many thanks again.
    https://forum.manjaro.org/t/cura-version-5-appimage-failed-start/123516
    On the console for example with cura 5.2:
    QT_STYLE_OVERRIDE=""  ./Ultimaker-Cura-5.1.1-linux-modern.AppImage
    many thanks again.
    @alfcura - Thanks for the response. Sorry for not updating this sooner, but I found an answer on another forum (I want to say the cura git page). From what I found, I created a script tor starting Cura and linked it to the icon which is very similar to your suggestion, so thanks again.
    #!/bin/bash
    ## wrapper for Cura 5 to unset QT style
    unset QT_STYLE_OVERRIDE
    /home/jason/appImages/cura
