- 2 weeks later...
I have the feeling that you printed this a bit too hot and too fast. Also, white often does not print too well, I am not sure why but I guess because it has fillers to make it opaque white. Further, older filament might be moist, or it might have become too brittle or too hard to feed well. If the spool is nearly empty, a hard and tightly wound filament will cause a lot of "unwinding resistance" (=it acts like a spring and wants to wind-up again) and cause a lot of friction in the bowden-tube and nozzle, causing under-extrusion. This is a known issue with the UM2. If so, you could unwind a bit manually, bend it in the opposite direction around a skater wheel, release again: this will straighten it somewhat, causing far less friction and resistance.
For best quality, print slow, in thin layers, and cool (=at the bottom of the temp-range of the material), with new filament, at the beginning of the spool (or if at the tight-wound end, after straightening the filament). For example, printing 0.06mm layers, 25mm/s, 190°C for PLA, will give good quality, but will cost an endless amount of time, 12x longer than printing at 0.3mm and 50mm/s...
Most of the time I print PLA at 210°C, 35-50mm/s, and 0.1-0.3mm layers, with decent quality, good enough for the purposes.
If you are relatively new to 3D-printing, or on an unknown printer, make a small test model, and print that with different settings. Or change the settings on the fly while printing (temp and speed), to see the effect.
Pictures:
Testprints at various speeds and layer-heights: from left to right: 0.4, 0.3, 0.2, 0.1, and 0.06mm layers; top row at 50mm/s, bottom-row at 10mm/s. Material is PET, transparent to see what happens inside. The watermark is halfway inside the model. Test-block dimensions are in mm: 20 x 10 x 10, hollow watermark text is 3.5mm caps height and 0.5mm leg width.
High-quality print with 0.06mm layers and ca 0.35mm/s (if I remember well). Ruler is in mm and cm.
Standard quality print at 50mm/s.
Unwinding and straightening a bit of old, stiff and too tightly wound filament, by bending it around a skater wheel in the opposite direction, then releasing it again. After that, its bending radius is about 30cm, the same as that of the bowden tube, thus causing almost no more friction and no more unwinding resistance in the feeding system.
Hey @oskars
Can you double check if your bed is levelled correctly?
You can find the instructions here:
https://support.ultimaker.com/hc/en-us/articles/360011886719-Build-plate-leveling-on-the-Ultimaker-2-
Smithy 1,141
I would try to print slower, 40mm/sec and try a new spool of filament and use not the cheapest one.
