On 8/18/2022 at 4:36 PM, gr5 said:You might just want to grab the cura engine from the appImage files for the linux version of cura and see if it launches as is
That's not going to work; the curaengine binary in the appimage is compiled for 64bit x86, which the UM3 (and newer) linux boards don't support. If any version is going to work like this, it is going to be the smartavionics/burtoogle build for the raspberry pi. But I agree with Smithy that the linux board is probably too limited to do any reasonable sort of slicing on the board.
Edited by ahoeben-
1
gr5 2,332
You might just want to grab the cura engine from the appImage files for the linux version of cura and see if it launches as is. I don't know the answer to your question but someone who probably knows the answer:
@nallath
@ahoeben
Smithy 1,146
Just keep in mind that the UM3 Linux board is very limited from the resources.
