Posted
· Tips to close open gaps at the top of a figurine.
Hey burleysavage,
It's a bit hard for me to judge what is going on just from the pictures.
I ususally try to avoid changes in speed and temperature, they have a lot of impact on your quality so I try to stick as close as possible to the default settings.
But there are several settings that improve top faces:
- Increase Top Layers - This will add more material at the top layers
- Increase Skin Edge Support Layers - This will build up a structure to support the top in the infill
- Enable gradual infill or select the Lightning Infill Pattern - This will also build up a structure to support the top in the infill
- Lift Head - This will give the layers time to cool off before starting a new one
MariMakes 177
Hey burleysavage,
Good luck!
We have a webinar about how to print tiny miniatures. There are similar tips mentioned there.
https://ultimaker.com/learn/printing-small-parts-and-fine-details-webinar
