Hello gr5,
thanks for the fast reply.
The project was a ER Collet holder from thingiverse. In my attempt to troubleshoot i reverted to the standart print profiles to be shure its not a setting problem.
When i was loading the Material i noticed that the material was moving in a stop and go motion and made a scraping noise untill it entered the guide tube of the Printcore. (see Video)
I had just cleaned the Bowdentube and Feeder, so it schuldn't be dirt.
The fan starts blowing at 60°C as intendet.
I just made the same flow tests on the left core/Side and even with the Solex Core.
At the moment the Core setup is original Ultimaker Core on the left Solex core on the right.
the extrusion seems to be fine in both cores.
We use PLA from ICE
gr5 2,094
The 3 holes definitely improve flow - there are some great videos from "CNC Kitchen" on youtube basically proving that it's much better.
It's good to have some tricks to isolate the problem.
Trick 1: Test feeder. It's probably not the feeder but it might be so let's eliminate the feeder right off. The feeders do age - there are some plastic parts inside that can completely wear out. So lift that lever and pull back the filament so that it is half way down the bowden. Now go into the menu system and get to the MOVE feature where you can move the material - move the material and then fight that by pulling hard down below the feeder with the other hand. The feeders typically fail at about 7kg of force where the filament slips backwards but anything over 4kg should be plenty. Maybe lift a 5kg weight (if you can find something - or maybe a few liters of water?) to compare the force or I've kind of squeezed a 5kg weight against the filament below the feeder such that the filament is basically holding most of the weight. Make sure the feeder can advance the filament forwards while being held back by 5kg.
Trick 2: now test flow. See how fast you can extrude through the nozzle. Typically you can get the filament to go from the nozzle down to the bed (when all the way down) in about 10 seconds with a 0.4mm nozzle. If it takes > 20 seconds then there is a problem somewhere. Again - in the move menu, it will heat the core. wait for the nozzle to heat up and then turn the knob to get the filament to move. Try to find the max speed. Put a kink in the filament just outside the nozzle so you can see how long it takes to get down to the glass. Slowly adding movement with one hand constantly to try to achieve max speed (if you move too fast with the feeder it can actually slow down a bit).
1) Please post your project that definitely failed. If you don't mind sharing the STL. Go to "file" "save project" and post the resulting file here. Just so I can see if you are printing too fast or something I wouldn't normally expect.
2) Make sure the fan is working in the print head - the center fan. It should start spinning as soon as either core is above around 60C.
3) Is the problem only on the right core? You only show a photo of the right feeder.
4) Is this PLA?
