I got an Ultimaker spool that had an unwritten tag. You can get NFC Tools and read the tag and see. I tried some other apps but they don't let you see the actual memory where data is stored. On this app, go to the 'Other" in the main menu and select read/write. then scan the tag. Pick any address slot and if you see all 0's then you know you have a bad tag.
if you see two character memory values, then you know the tag has been written to.
Anyway.. thought this might help you. I thought I was going crazy and my material handler was failing.. but it was a cheap NFC tag that caused my headaches.
MariMakes 178
Hey @KjetilSunde
This seems like a hardware issue. Perhaps a loose plug.
I really don't recommend opening up your material station yourself.
If you contact your local reseller they should be able to actually help out.
You can click here for a support ticket
Good luck! 🤞
