Why Cura 5.1 printing beyond workpiece?
Badgersurfer
Posted (edited) · Why Cura 5.1 printing beyond workpiece?
I have been doing a series of stringing tests on eSun Silk PLA and noticed that for some reasons the nozzle travel is going well outside the workpiece. I am confused by this as it obviously makes the job take considerably longer and also causes unnecessary stringing. Have I missed a setting here somewhere? image.thumb.png.5886de8e7385321d29e3af3dc83292ca.png
Edited by Badgersurfer
    Posted · Why Cura 5.1 printing beyond workpiece?
    I have moved the workpiece to the center and the travel lines have moved accordingly . So it seems the nozzle is doing something that is aligned with the centerpoint on the X-axis. I thought maybe this may be to enable it to retract and extrude for the next layer? I have set retraction off and there is no difference. image.thumb.png.bb276a8508dc5ab3c0fd270bbe475536.png
    20 minutes ago, GregValiant said:
    In the Experimental section see if you have "Wipe Nozzle Between Layers" enabled.
    Another setting that can give that behavior is in the Cooling section called "Lift Head".
    Yep thanks for that it was the "Lift Head" setting. I will see if it makes any difference to my print now... interestingly it halves my print time from 10mins to 5 mins...
