GregValiant 1,112
- There was nothing in any of the videos I watched that said "Do not use a double boiler to melt milk chocolate because it will never get firm again."
- It is a bit of a messy operation.
- It is a bit of a messy operation. (just in case anyone missed #2)
- Mechanically and software-wise it seems to be fine.
- The lead on the aluminum plunger doesn't want to fit into the silicone seal. The result (admittedly after only one attempt) is that the silicone piece cocked. There will be some rework there.
- A huge plus is that scrap material is really good on ice cream.
I'm putting the printer back to plastic for a bit so I can print a stand to hold the plastic containers vertical. Filling them was the biggest part of the mess. Then I'll give it another go.
GregValiant 1,112
All the chocolate in the house has nuts in it. I'm guessing they won't pass through a .84 nozzle. At some point I'll get off my butt and get some proper Hershey's nuggets.
I did a dry run of a simple vase and all the motion looked good. My printer is also an Ender 3 Pro so everything went together as it should. The wiring is sort of festooned over the machine. That will need to be addressed.
I did make some changes to the start up gcode. I don't know that "#" is a proper comment character. I changed them to semi-colons.
I added the M302 S175 and M92 S97 to the Ending Gcode. M302 self-resets anyway and I figured if I set the Esteps back to my normal setting after every print it wouldn't hurt anything.
