Problem with material extrusion and active leveling (Ultimaker S5)
Posted
· Problem with material extrusion and active leveling (Ultimaker S5)
How many hours are on the core? I'd try the other AA core that came with your printer. Or get a new core. They are considered to be "consumables" by Ultimaker. Similar to filament. And Ultimaker was nice enough to keep the price pretty close to cost for cores.
The PTFE can age from the heat but I still have all my original cores.
Basically there are several components at and above the heat break that set the internal diameter. There is the steel heat break (inside the heatsink) and the PTFE tube (about 2cm long inside the heatsink) then there is to top of the aluminum heatsink for maybe 5mm and then the top tube. Steel. Ideally everything should be exactly 3mm in diameter but sometimes the PTFE might be say 3.1mm in diameter (or the heat break). When you do retractions and also just heat creep can cause the filament to expand into that 3.1mm space and if it hardens then you have a wider section of filament that has trouble getting past the heat break or trouble exiting the core (upwards) or has trouble when re-inserting.
Or maybe it's nothing to do with any of this and the filament sensor in the feeder needs cleaning or replacing or maybe you need to angle the filament better. Or disable the filament sensor (I think mine is disabled? I forget but my S5 hasn't complained about filament issues in years).
Seriously consider taking apart the feeder - if you only remove the 2 screws it's easy to get back together as the rest is still well attached to the printer but be very careful with that strong spring and how it goes back - most people put the spring/screw back in incorrectly and then their feeder is at the minimum tension after that so look at a video or something. And see if there is a mess to be cleaned particularly around the sensor.
Or if you don't have the Material Station, look at how the filament sensor works and consider putting the filament on the floor. The angle that the filament enters the feeder matters to the filament sensor.
gr5 2,071
