Known Leveling Issues with Ultimaker S5s and S3s - [SOLVED]
MariMakes
Go to solution Solved by MariMakes,
Posted · Known Leveling Issues with Ultimaker S5s and S3s - [SOLVED]
Hi all,
Just a quick message from the Community Manager.
We noticed an increase in failures due to bed leveling starting from Firmware 7.0.4 and higher.
We are aware of the issue, found the cause and our team of developers and testers are working on an update that should resolve this.
We are asking for your patience while we follow the proper procedures to deliver you an updated version of the firmware.
We apologize for any inconveniences.
Let's hope we have an update soon! 🤞
------- Update ---------
A new firmware version with a  is available and can be downloaded here:
https://support.ultimaker.com/hc/en-us/articles/360011545559
  • MariMakes featured and pinned this topic
22 hours ago, dsp said:
for us this was cause by the switch to choose the correct core lost its position a simple recalibrate worked.
Yes that can indeed fix this error as well. There are multiple failure modes that produce the error in the picture
If you see the error in the picture it doesn't mean that it was because of the new firmware, but if you suddenly started seeing it when going to 7.0.4 it might be because of the update
    • Solution
    A new version of the Firmware with a fix has been released! 🎉
    You can download it here:
    Or on your printer on the latest channel.
    Release notes can be found here:
    https://support.ultimaker.com/hc/en-us/articles/360012055979
    Happy Printing 😄
    • MariMakes changed the title to Known Leveling Issues with Ultimaker S5s and S3s - [SOLVED]
    • MariMakes unpinned this topic
        • 9 replies
