Hey All,
It seems I haven't followed up on this. 😅
I discussed the issue with the team and they also see value in adding a way so certain settings always show up when you use a modifier mesh if you work with a lot of them.
For internal reference CURA-9668.
Let's hope it gets a high enough priority to implement soon.
Fingers crossed 🤞
Andrew_W 9
I've the same question, looking forward to an answer.
MariMakes 208
Hey @Badgersurfer,
I see some value in this request.
I wouldn't know how to do it, so I'll have to ask the team.
Fingers crossed 🤞
Badgersurfer 2
Well done. If you do maybe you can pass this idea to them as well. I use several different blocks for different processes and if one overlays the other it would be a great advantage to rename the default names you give them.
