Posted · Changing Material Profiles for Ultimaker Materials in Cura
Hey @DerekTakeno
Welcome to the Ultimaker Community 🚀
Recognize your struggle. There are two ways around this.
Method 1:
In de custom settings > Material settings > reduce temp
Save as dummy project
Load this project and load files to repeat good results
Or one that might be easier Method 2:
Duplicate your material
Change the name slightly
Change the temperature
Select this duplicate material when you want to slice
Can you let us know if this works for you?
Thank you! 😇
