Print has large gaps between support and print
AstroCity
Posted · Print has large gaps between support and print
I am not sure what happened. Yesterday I printed off some minis just fine but today when I went to add supports cura just refuses to let the supports actually support the print.
you can see the large gaps from the support to the print itself. I do not know how to fix this and it is driving me crazy
    There are 73 settings in the Support Section of Cura.  You need to make adjustments until you get a structure that works for the model.
    Use the visibility tool to the right of the Settings Search box and set it to "All".
