Hey @FGoOse,
Just curious.... Why would you like to change the thickness in the layers?
Are you interested in time reduction or a strength increase?
I think there might be other settings that can help you here.
If you share a file we can help to troubleshoot.
GregValiant 1,491
Hello.
There isn't really a way to affect the Z moves themselves. Using "Adaptive Layers" will give you different layer heights in certain areas of a print. They are calculated by Cura so you wouldn't really have any control.
There is a setting for "Alternate Extra Wall" that will add a wall every other layer into order to trap the infill better.
You can use a support blocker with the Per Model settings set to Modify Overlaps. You could set the Wall Count to whatever you want. I use that for extra material around holes that are for screw connections.
This is with a thick support blocker configured to Modify Overlaps and as an Infill Mesh with 10 walls while the main model has 3 walls. You can see that it adds an extra wall feature through the middle of the part although the model file does not have a wall there.
