12 hours ago, GregValiant said:The main reasons for the plastic not sticking are a dirty build surface, the bed wasn't leveled correctly, the E-steps need to be calibrated.
When the build surface is new (either the magnetic one or glass) it may have some finish on it. Take it off the printer and give it a good wash with dish detergent. Put it back on the printer and warm it up to 50° or so. Give it a good wipe with isopropyl alcohol (90% is best). Even fingerprints leave enough oil on the surface that the plastic doesn't stick.
The only way for the printer to know where the build plate is in the Z is the bed leveling. Did the printer come with an an Automatic Bed Leveling system? If it did then you may need to adjust the Z-offset. If you level with a piece of paper (I do) then use a store receipt or parchment paper. You need to develop a feel for it as you move the print head and adjust the leveling screws.
If the E-steps aren't adjusted correctly from the factory (and most Enders are not) then it's quite possible that the printer isn't moving as much plastic as the gcode is asking for. That means you aren't getting enough squish between the nozzle and the bed so the plastic isn't getting smeared.
A fella named CHEP has videos on YouTube that he calls Filament Fridays. He is very Creality centric and I'm sure he covers both bed adhesion and calibrating the E-steps.
When you level the build surface you are telling the slicer "Here is Z=0". If the nozzle is actually .1mm above the build plate then the gap is too large and the careful calculation made by a slicer program will be wrong. If you have the "Initial Layer Height" in a slicer set to 0.2mm and your nozzle starts out at 0.1 instead of 0 then the first layer will be 0.3mm high. The amount of plastic needed is 50% greater than the gcode is supplying and so there is no squish and your print just slides around and becomes a mess.
Everything one the printer is fine since it is able to print the given G.code that came with it. The problem I can see is from the slicer instead
GregValiant 1,492
