Why is Cura not slicing the opening in my model and is ignoring it.
hafeez8
Go to solution Solved by GregValiant,
  • Solution
Posted · Why is Cura not slicing the opening in my model and is ignoring it.
@hafeez8 the model has errors .  I was able to repair the model using the Mesh Tools plugin and the Fix Normals command.  MS 3D Builder is more capable and would also repair it.
The model on the left has been repaired by 3D Builder.
If you are using Blender or TinkerCad you should always check the models for errors.
  • Heart 1
THANK YOU!, a huge help!
  • Heart 1
