These configurations require the printer somehow communicating with Cura what material and nozzle size is currently configured on the printer. The Ultimaker 3, S5, S3 and 2+ Connect all communicate with Cura through a bespoke protocol, either via the Ultimaker Cloud or locally (AFAIK, the latter is not available with the 2+ Connect; that printer only supports the cloud connection). The Cura-part of that bespoke communication can be found here: https://github.com/Ultimaker/Cura/tree/main/plugins/UM3NetworkPrinting
You are going to have to write (or extend) a plugin that communicates with the printer. That plugin will have a subclass of the PrinterOutputDevice, and that subclass needs to implement a uniqueConfigurations property which returns a list of PrinterConfigurationModel instances.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ahoeben 1,886
