Thanks for thinking about it.
None of the combing options work because the whole part is split by the hole which is where things go awry. Sometimes I will design in a line that I have to drill away just so there's no break in the external wall to allow combing to work.
Drill holes are the most common case where this occurs but anything that splits an otherwise straight walled part will cause wild travel and subsequent stringing artifacts.
Perhaps another way to look at is as trying to select a minimum external travel distance for each layer and another option could even be a "same as previous unbroken layer" travel option.
The part here is a clip for a celestron telescope tripod if you're curious.
MariMakes 178
Hey @m12lrpv,
That's a really interesting challenge 😄
Do you have a project file for us?
To save a project file go to File -> Save project.
On the top of my head I would say that the Within Infill combing option would help you here.
You can read more about it here. https://github.com/Ghostkeeper/SettingsGuide/blob/master/resources/articles/travel/retraction_combing.md
