Posted · How to suppress the annoying File Save confirmation windows?
every time I save a 3mf or .gcode file, I get an annoying pop up window telling me what and where I saved, and I have to click the 'X' to close the window. How to get Cura (v5.x) to stop popping up these windows?
    There is no out of the box option to disable these messages, beyond editing the code*.
    The message should disappear automatically after 30 seconds.
    *: if you want to go that route, you would need to edit
    C:\Program Files\Ultimaker Cura 5.x.x\share\uranium\plugins\LocalFileOutputDevice\LocalFileOutputDevice.py
    The easiest option is to remove the entire line that says `message.show()` at (around) line nr 198.
