here is the project file,
i should explain a bit more:
the part i have shown is just a section of the parts i am trying to slice, which are larger and thicker (about 200x70x8mm)
only the top surface is curved and requires fine layers to be smooth enough:
, but the first 5-6mm are simple perimeter and infill:
additionally, this is a 2 color print, and cura also adds top and bottom layers between the two colors.
slicing the full size models with 0.05mm layers, 8 top layers, 20mm/s results in over 24h print time.
slicing with adaptive layers is about 8h (but there is this issue with speed and top layers)
also, printing all layers at 0.05 results in weaker parts
so finding a solution can be very benificial for this project.
(in the past, i used simplify3d, with seperate processes to control settings)
to anwer your other questions -
these are functional parts, so they need infill and bottom layers for rigidity.
thanks again,
noam2
MariMakes 208
Hey @noam2,
Welcome to the Ultimaker Community 🎉
This is an interesting challenge!
From the top of my head, you can't adjust the adaptive layerheights this precisely.
But there might be other ways we can decrease your printing time.
What's the reason you want to decrease the printing time?
What is the print used for? Can we for example remove the infill or the bottom layers?
We can help you better if we have a project file.
It contains the printer and settings I need for troubleshooting.
To save a project file go to File -> Save project.
Thank you 😊
