No, I didn't notice any stuttering. But if the print head was stuttering what might be the cause and how might I change that? I'm using the 4.2.7 silent board and my sd card should be fast enough. Thanks.
Hey @PeterPan,
Welcome to the Ultimaker Community 🚀
I agree with @GregValiant that it looks a little like Buffer Underrun.
This might be an odd suggestion but have you tried turning off you interruption recovery feature on your 3D printer?
Do you also see these artifacts if your model has a lower meshcount? Because your printer might be processing a lot of small line segments and having to think about it.
Hello @MariMakes,
I have deactivated the power loss recovery for exactly this reason if that is what you mean. Is there any other interruption recovery that I should know of?
I have never looked at the meshcount. I always just import the stl from Inventor to Cura and that always works. Well, until now. Maybe I should look into that.
Which software would be the right one for adjusting the meshcount? I think Angus from MakersMuse uses MeshMixer, would that be a good one? I don't think that I can do that in Cura, can I?
I have worked a lot with the firmware. Could I have messed up anything there? I think there were some buffer settings or something like that.
Thank you very much.
Edited by PeterPanHey @PeterPan,
You should be able to define the amount of detail when exporting your mesh in inventor.
You can also try an online Mesh Simplifcation like https://myminifactory.github.io/Fast-Quadric-Mesh-Simplification/.
There are also other ways to reduce your buffer underrun like slightly increasing the Maximum Deviation setting or changes that are more specific to your printer since it seems to be your firmware that is acting up.
Hey @MariMakes,
these ideas are all very interesting and I'm definitely going to try everything out.
Is there an upper limit of mesh size that I should stay under or does it depend on the object?
Could I adjust the buffer size or the number of linear moves in the planner in the firmware to deal with this problem?
Can you think of any other firmware setting that might affect this issue that I could change?
Thanks for your help.
GregValiant 1,141
Did you notice if the print head was stuttering? If it is stopping for just a fraction of a second you can get divots like that as the nozzle re-softens the plastic near it.
