Now to answer your question more directly about cleaning the nozzle, look up "cold pull". Either for UM2 or really any printer. Read about the process and try to do that. That will clean the inside of the nozzle. I'd try it at least 5 times. The tip of the filament should look exactly like the inside of the nozzle including the thin section at the end (I assume 0.4mm).
You can do the cold pull with TPU but I'd do it with nylon or pla.
To clean the outside of the nozzle, just heat it up and wipe with a paper napkin.
gr5 2,099
TPU is more hygroscopic than ABS or PLA and I suspect you need to dry your filament. It only takes a few days in typical (40-60%) humidity for many materials to be "ruined". This definitely includes PVA and NYlon but I'm not sure about TPU. Likely it's a problem for TPU.
Check where your TPU softens and goes to a clay like material by heating up the bed to say 80C and putting a few cm of TPU on it and with a towel over it for about 1 minute and then squish it to see if it bounces back or not. If it does then I would uncoil enough TPU for your print and put that all on the bed and the spool on top and heat the bed to 75C and put a towel over all of that and let it sit overnight to get most of the water out.
