You want to get the humidity incredibly low - around 15%. I don't think most of those storing stations get that low. Personally I use a combination of rechargable desiccant and the heated bed method I mention.
I bought a liter of desiccant and use about a 1/2 cup of it in a 2 gallon (mixing metric and imperial, lol) ziplock which is big enough to hold the container of desiccant and a spool of filament. I also use a humidity sensor which is crucial as before I started using the sensor I realized I was only getting the humidity down to 30% which wasn't enough. I dry the desiccant in the microwave. 30% humidity is much too high and gives me horrible results.
The desiccant is only used to maintain dryness. To dry the filament I use the heated bed.
It's all a bit of a process but necessary for PVA and Nylon.
gr5 2,072
There are 2 common problems with PVA. If you are seeing black gunk and material isn't coming out you may have caramelized it. On the UM3, in the menu system under I think "maintenance" maybe there are instructions for doing hot and cold pulls. Follow those to clean out the nozzle.
More likely your problem is due to water absorption. Even just 24 hours at typical (40-60%) humidity can wreck PVA. Restore it by heating your heated bed to 55C. Unspool enough for the prints you will do that day (cura tells you how many meters are needed. Place that on the bed and the spool on top of that (the spools can warp even at 60C but if they are a few mm above the bed it will be fine). Put a towel over all that. Maybe 3 or 4 towels or a blanket or something. Leave it like that for 24 hours (certainly at least 8 hours at 55C, less time needed at say 70C but that will probably cause the PVA to deform - I do this to nylon at about 70C - PLA doesn't need to be dried).
The meters of filament you unspooled will now be miraculously just like new.
jchojnacki 0
Thank you, I had a feeling it was more of a material issue. Do any of you use the dehumidifier storing stations?
