Visible travel lines on top surface
Tsims0311
Posted (edited) · Visible travel lines on top surface
I've tried a few of these prints with various setting changes but can't seem to reduce the visible lines on the top surface. I'm using the ironing setting which seems to work well other places. Any thought on what might be the issue here?
NOTE: The part in that file has a layer overtop of the holes as an attempt to avoid the printer trying to iron around the holes.
Attached is a picture and my project file so you can view my settings used. IMG_3528.thumb.jpg.324176c782d7739bcc38929530e73d84.jpgUMS5_Test Plate5.3mf
Edited by Tsims0311
    Posted · Visible travel lines on top surface
    36 minutes ago, Smithy said:
    Check if you have set Combing mode to Not in Skin - that should help.
    I've had not in skin enabled for all prints of this part. Could it be an issue with the retraction speed/oozing during travel?
        • 6 replies
