I don't know if it's still the case but I've notice that the minium release was OpenGl 3.2 to have this function. But a release 4.1 is recommended as minimal configuration. To get more information on the current driver of your graphics card on Windows you can use an utility Tool like GlView : https://www.realtech-vr.com/home/glview
If you also use an othe slicer like PrusaSlicer or SuperSlicer in the System Function you can have this information. ( Should be also a function of Cura as many issues comes from this limitation , but it's not the case right now )
Cuq 184
Certainly because your graphics card is not compatible, must support the right OpenGl version.
snekmeseht 0
Thanks. That sounds like it may be the cause. Is there anyway for me to verify?
