I'm sorry, I don't speak French but I think I can help you.
I don't have a Delta mini v2 but I can tell you that we need a little bit more information to troubleshoot.
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
In expect that in this case we might also need your configuration folder.
You can share your configuration folder by:
Go to Help at the top bar of Cura
Select Show Configuration Folder
Select all the folders in there and create a zip OR go up a folder in your folder structure and zip your folder with the correct Cura version
MariMakes 198
