Posted (edited) · How to remove gaps in 100% infill?
Hey,
I am trying to reduce the gaps of 100% infill but the parameters I am tweaking does not seem to work. In the Pursa Slicer, there was "Infill/perimeter overlap". If set over 110% it usually vanishes. Would appreciate if anyone can help me out?
Edited by Nikun19
Solved
    Posted · How to remove gaps in 100% infill?
    You can try setting the "Extra Skin Wall Count" to "0".  Cura won't apply the overlap to that extra wall but if it isn't there then the overlap works correctly on the inner-walls.
    There are a couple of bug reports on Github about this behavior (#12294 and #13553).
