Do I understand the question right?
Your brim is not close to the edge and it still says your out of bounce right?
But if your model is over the edge of the build plate (higher up) the print nozzle can't reach it as well.
I think that is why you get the error right?
Once I had a model that was as big as my entire build plate but Cura thought it was to big.
So I had to manually change the build plate size in Cura to let it be sliced (but I only did this because I was 100% sure it fitted) this could be a solution.
gr5 2,069
Yeah this is a bug that I've known about. It sucks. Another brim "bug" is that sometimes it ends up "inside" the part where I don't want it and it is extra hard to remove (I put bug in quotes because in the case I'm thinking of, "inside" is topologically still outside in my specific case because there is a purposeful crack leading to the exterior of the part). Anyway...
That's a tough one. My understanding is that other technologies such as injection molding need much more modifications to the design than FFF printing. You even have to change the angle where the edges come together in corners (in other words corners of the mold are not at 90 degrees if you want the final part to be 90 degrees. Crazy. So it's wonderful that you have to change so few things in FFF printing (between desired part and model sent to Cura).
Also in FFF I have to make all vertical holes about 0.4mm larger than specification.
The difference though with injection molding is that there is a second engineer at the mold company who does all the modifications to your 3d model. I think I prefer 3d printing where the modification is done by the primary designer.
Adding a brim in CAD is pretty easy. It can be on a secondary layer that is turned off by default so most people don't notice it? I occasionally add brim in CAD because I can only put the brim on the extremities/corners and this saves lots of time removing the brim later.
Sorry I'm not helping with your question. But wondering if you might want to think differently about the overall solution to dealing with CAD models not matching final product and process flows.
