UlrichC-DE 108
Hi
Yes, unfortunately I know the problem too. I then use generic profiles and get the same result.
Background could be that the parameters for unloading the materials are only on the printer itself hard deposited.
Everything that can be unloaded without problems with the existing profiles is compatible, everything else is not.
Ultimaker likes to point out that these releases for the material station give the manufacturers themselves.
Practically, however, probably Ultimaker itself stands in the way. For example, by not being willing to make these parameters accessible in the material profiles.
The material is apparently properly pulled out of the print head but the sensors go on alarm.
It is obvious that the material sensor gets a bit confused when more material has to be pulled.
At the end of the material, a thickening tends to form during such actions. This could then not be pulled through the material station in every case.
Therefore ER64. If you bypass the error and the assistant (e.g. by switching off the printer) you will still not get the material back into the station in some cases.
If you rebuild on the spool holder, the material remains in the printhead until you manually unload it.
At least this way you get rid of these considerable maintenance times.
So was my knowledge stand over a year ago. Perhaps something has changed.
I also hope that Ultimaker creates a solution for this.
greetings
scottjkolb 0
Flyntm,
This is an ongoing problem with my Ultimaker. Super frustrating. The only material my machine sees are the originol Ultimaker materials that i purchsed with teh machiner which have now run out. Backspooler doesnt make a difference. I have been looking for answers on this for some time and will now post on the message baord. Good luck!
