Cant import profiles
Lappen71
Go to solution Solved by Lappen71,
Posted · Cant import profiles
I have a Ender 3 v2 and uses Cure 5.2.1 but I can't import profiles.
The profiles are downloaded från Creality because I have a Sonic Pad.
https://www.creality.com/pages/download-creality-sonic-pad?spm=..page_1934481.products_display_1.1&spm_prev=..product_63450b4c-43c8-4324-9b18-1172e81585f2.footer_1.1
Other people have been able to import but I only get error message.
Does any one have any idea whats wrong?
    Hey @Lappen71,
    Welcome to the Ultimaker Community 🎉
    Your Creality Ender-3/Ender-3 V2 comes with a set of profiles.
    Are those not working for you? Why do you want these additional profiles?
    I checked the webiste that you shared and I'm getting the same error message.
    This is not how I would share the files.
    If you want to see the settings in the profile you can open it in Notepad or Notepad++.
    This is what I see when I open th ABS file.
    You can copy the settings that you want over.
    Here is a cheat sheet for how the settings look like in Cura vs how they look like in the code.
    https://github.com/Ultimaker/Cura/blob/main/resources/definitions/fdmprinter.def.json
    I hope this helps! Good luck 💪
    • 2 weeks later...
    • Solution
    Sorry for later answer. Yes Cura comes with set profiles but the profiles Creality has for the Sonic Pad is better.
    But anyway i solved it. I had to start with a new printer profile then it was possible to import.
    • 3 months later...
    I'm having the same issue.  Could you elaborate on start with a new printer profile?  I can't seem to get this, i've tried adding a new printer same error.
