Best material for a working prototype?
Posted · Best material for a working prototype?
I have a part I'm needing to print.  The material must be very strong but I need it to have a slight flex for a rope to release through. Picture is just an example I pulled from Thingiverse.
It will be similar to how this works.  I am using an Ultimaker S5 Pro Bundle
    Hey @JohnWilkerson,
    Personally I use PLA for a prototype and move to a different material if it breaks.
    Will it be used outside and will it be wet?
    You can also consider taking a glass or carbon fiber filled composite.
    You can read more about it here:
    https://ultimaker.com/learn/glass-vs-carbon-fiber-composite-3d-printing-materials
    I have a Balcony Garden made with PVC pipes.
    They need to hold the weight of the plants, and the water and are attached with a tiewrap.
    I've printed these in Nylon and some TPU for grip.
    This Nylon has hold up for 2.5 years now and has not failed me yet.
        • 4 replies
