Posted
(edited)
· how to remove the disallow border in cura
Yes, they were moved down a folder to "C:\Program Files\Ultimaker Cura 5.2.1\share\cura\resources\definitions"
The easiest thing to do is install an Ender 3 Pro and use that one. It doesn't have the disallowed areas but it will install with the build plate at 220 x 220.
You can usually kick that up in the Manage Printers / Machine Settings to 230 x 230. You would need to set your "Home Offset" to 2.5mm in from the left and 2.5mm in from the front. That provides a 2.5mm safety border around the glass. I think you can use the stock magnetic bed at 235 x 235 but the glass has a 1mm beveled edge and so it isn't really quite 235 x 235.
If you would rather alter the Ender 3 definition file you would delete:
GregValiant 1,346
"machine_disallowed_areas": {
"default_value": [
[[-117.5, 117.5], [-117.5, 108], [117.5, 108], [117.5, 117.5]],
[[-117.5, -108], [-117.5, -117.5], [117.5, -117.5], [117.5, -108]]
The problem with doing it that way is your "custom" definition file can be over-written when you upgrade Cura. You could do it again of course.
