cloakfiend 995
As for pla and acetone dipping to get better surface quality, dont bother under 0.1mm layer height, id reccommend 0.06 however the benefit of dipping PLA/PHA is a change of state. The pla/pha becomes easier to sand after dipping. Im printing a helmet soon and most likely will hit the bondo. I never print large so will most likely use .2mm layer height. Ill document my build as it has a moving part i cant acetone all of it due to fear of warping but defo in some areas to improve the sanding abilitly rather than quality.
Armatron 2
Thanks i think i will do that, but a little Rock from my Spotify it should be good.
