Finder setup with different be height?
Bazmundi
Posted · Finder setup with different be height?
Hi, I am playing around with adding a heated bed to my Flashforge Finder.  The result is that the bed is about a 1 cm higher than stock.   I can't use the Flashforge slicer, so looking at Cura to get around this, given the Finder can be configured as a printer in Cura - at least according to multiple videos on the topic.
I accept the build volume will be less.  But has anyone a suggestion on what other parameter is to change to set the higher bed position please?
Cheers,
Baz
