Cura: Setting priority printer versus filament
Axador
Go to solution Solved by ahoeben,
Posted (edited) · Cura: Setting priority printer versus filament
Good day together
I'm doing my first steps with 3D printing and calibrating my printer in Cura 5.2.1.
Now I have come across the point that I have found the values retraction speed and distance both in the filament setting as well as in the printer setting and do not understand which values dominate in the end, respectively I have to set for the calibration.
I do not have to create a separate pressure profile for each filament, right? Which of the values that occur both in the filament as well as in the printer setting I have to calibrate?
I hope that I have expressed myself clearly and am curious about your answers.
Edited by Axador
    • Solution
    Posted · Cura: Setting priority printer versus filament
    If you change a setting in the "Print Settings" floater (on the right of your screenshot), that always overrides what is set in the Materials pane of the preferences.
    If you do not have a value set in the "Print Settings" floater (and the profile you have selected doesn't either), then the value set in the Materials pane of the preferences should carry over in the "Print Settings" floater. However, it is very possible that the profile you have selected overrides the value from the material.
        • 9 replies
