The "Fill gaps between walls" setting is gone. The "variable line width" of 5.x versions replaced it.
In the Wall Settings section of Cura are new settings to adjust this. Try lowering your "Minimum Line Width". The default for a 0.4 line width is 0.34 so try making that 0.30. There are other settings too play with as well.
1
GregValiant 1,346
