- Solution
Thanks for your answer but in fact, I found the solution. I have to use the printing mode Both (not Normal, not Surface, but Both). If my drawing is correct, it works perfectly, I can obtain external surfaces in Normal (o,8 mm for example) and internal structure in Surface mode (0.4 mm), and I can chose the dimensions of my horizontal surfaces.
Then now, all is ok for me.
MariMakes 192
Hey @Emmanuel0344,
What an interesting question. There is not something that jumps to mind other than Spiralize Outer Contour.
But I think there are plenty of people here that can help.
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
