Hi @GregValiant thanks a lot for the quick response!
I'm attaching the export (even if Cura generates a zip which I'm not allowed to attach here, so I added .3mf, hope it works).
I don't understand why the pupils start at level 51, as far as I know, they're drawn in yellow so I understand that's the "top"? Shouldn't cura automatically fill those areas that are too shallow to have support?
As I said I'm really new into this (but I am not a novice at all in computer science), so I did take a PDF from this logo, modified it a bit in Tinkercad and generated an STL. There might be a lot of tweaking to be done.
But I actually scaled it down to 70mm width (about 50%) and those pupils are printed "fine". However if you look at the letters AND for example at the tip of the ear, I don't understand why it does not follow a single line, but decides to make an up-and-down pattern. Same with the eyes...why it's not printing a circle? Is that a matter of walls size?
(I know that FDM is not fast 🙂 , it just that THOSE pattern in the walls looks very weird compared to the other "test slices" that I did - without actually print, of course)
I've bought a Creality Ender 3 S1. Based on a lot of research seemed a very good start...not too basic not too expensive.
GregValiant 1,141
Without knowing your settings there is no way to tell what is going on.
With the model loaded and Cura ready to slice with your settings - use the "File | Save Project" command to create a 3mf file. It will contain the model, your settings, and your printer. Much better to check than just the STL. Post the 3mf here.
I sliced that STL at .2 layer height and at layer 51 the pupils of the eyes start. There isn't anything below them so they will fail without support and getting support out from below that delicate structure isn't going to end well.
Regarding the time involved...FDM is not a fast process. You aren't allowed to complain until the prints get over 40 hours. When you wake up to a pile of spaghetti covering something that for 30 hours had been a perfect print THEN you get to complain as much as you want.
What printer did you decide on?
Edited by GregValiantLink to post
