Of course, I checked the temperature right after removing the nozzle, the plastic inside was still molten.
Well, first i tried to press "retraction" button in cura, I figured, it would be similar to turning the big gear)) Yes, I pulled it using my hands, really hard, it did not budge.
I really don't understand how can it be stuck. Both abs and pla should be liquid when heated to 245-260 C, and the filament should come out easily...
IRobertI 503
Something to check first, is the nozzle getting up to temperature properly? Try touching a piece of ABS to the nozzle after heating it to printing temp to see that it has actually reached that temperature.
When you say you tried to remove it manually, did you mean by turning the big gear or by opening the feeder latch and pulling on it with your hands? The reason I ask is that if you've only tried by turning the gear it might be that the knurled bolt has grinded the filament down so that it can't properly grab it anymore. It can also help to pull hard on the filament while moving the gear by hand to give it some extra power.
Next step is probably to either remove the bowden tube or take the head apart.
