Cura 5.1.0 and OS X Ventura 13.0.1 with M1 issue
Odissine
Go to solution Solved by Odissine,
Posted · Cura 5.1.0 and OS X Ventura 13.0.1 with M1 issue
Hello,
I just received my 3D Printer and want to follow tutorial to install Slicer tool from this link : https://formation.wanhaofrance.com/slides/slide/slicer-trancheur-82
After everyhing has been done, when I want to launch Cura program, OS X return an error says me Ultimaker-Cura is damaged and can't be open. You should put it in trash. ...
Is there someone who can help ? Do I have to wait for a fix ? Download and user older version ?
Thanks for you help
    Hey @Odissine,
    Welcome to the Ultimaker Community 🎉
    If you are importing profiles, you might have accidentally corrupted your configuartion.
    The best way to resolve this is with the start-up optimizer plug-in.
    You can download it here:
    https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/StartOptimiser
    I followed the instructions on the website you shared and I was able to load the profiles.
    So you might just need to follow the instructions again.image.thumb.png.9836cb59a81145299b2f0ca133d4bb05.png
    Thanks Mari for this tips ... After downloading python script (StartOptimiser and the other one) ... What should I do ? Copy paste ? Where ? Contents/Resources/ and next ?
    Thanks again for your help 😉
    • Solution
    Ok finally what I did is to unsintall Cura 5 and 4 ... Install them again , launch it first time before adding spceific config ... Just after launching apps, I copy past specific config for Wahahno 12 and now all is just fine 🙂
    So to conclude ... on Mac After installing apps, launch it once before adding plugin manually !! Thanks to all 😉
    • Thanks 1
